2002 MPV Computer / Immobilizer not communicating
Old 04-12-2017, 09:35 AM
joenspa's Avatar
Default 2002 MPV Computer / Immobilizer not communicating
I seem to have had my computer go out. It was not performing the emissions tests I needed to get my tag. We located a used computer, got it programmed but then the van won't crank. The tech that did the programming claims the computer has to stay connected to it's original immobilizer unit. That just doesn't seem right. That means that if any computer ever goes out that the car is done. I am thinking there has to be a way to reintroduce the old Immobilizer to the new ECU (computer).
Has anyone had any experience with this? Thanks!
Old 04-14-2017, 04:54 PM
Sparky202's Avatar
He is correct. Once the immobilizer is married to the PCM, they mate for life and I don't believe there are any virgin immobilizers still available. I haven't used one personally as of yet, but if you search pcm repair, some of them will take the immobilizer out of the programming.
Old 04-14-2017, 06:51 PM
joenspa's Avatar
So if your computer or the immobilizer goes out the vehicle is done? Or I guess you have to find a matched pair? Wonder if that's even possible any more?
I did find a used computer and it was programmed but then the immobilizer didn't work. That all sounds like what you are talking about.
The only problem my vehicle has is that it is not running the emissions tests. It is killing me that I have to junk a perfectly good vehicle because the computer module will not supply power to sensors for a couple tests. Any guidance or ideas are more than welcomed.
Old 04-15-2017, 04:04 AM
You can replace the PCM & Immobilizer as a set from a 2nd hand wreak.
Old 04-16-2017, 04:57 PM
joenspa's Avatar
Thanks. My repair shop has walked away from the job. I think I'll give this a shot on my own.
Old 04-24-2017, 12:56 AM
Sparky202's Avatar
Not surprised. Usually they run and offer to pay for the tow.
Old 05-11-2017, 04:40 PM
joenspa's Avatar
I have found what is suppose to be a new immobilizer. So my question now is, do we know if we can use a new immobilizer and a used computer? Is the handshake 1 direction or both directions?
Old 04-09-2018, 03:29 PM
joenspa's Avatar
Solved: I gave the car away to a friend that lives in an area that doesn't do emissions testing. Not happy but no other choice.
bobby79
08-17-2019 04:30 PM
robinsonjas
48
02-13-2019 02:57 AM
introuble
01-25-2010 08:24 AM
evanges
12-26-2008 11:31 AM
seaslide
12-01-2006 11:59 AM
Quick Reply: 2002 MPV Computer / Immobilizer not communicating
