2000 mpv rough idle/jumping - Mazda Forum - Mazda Enthusiast Forums
LinkBack Thread Tools Search this Thread
Old 12-20-2010, 08:16 PM
Default 2000 mpv rough idle/jumping
Ok so I'm kinda new at this so pls bear with me. I have a 2000 mpv that that check engine light came on a while ago. Van was driving fine until about 3wks ago. The engine jerks/jumps while in gear When it is in park it still runs bad. It sputters/ jerks. You can hear it in the exhaust. Van drives fine when accelerating until stopped. The rpm's are very low and the needle moves between 500 and a little lower. It seem like it wants to shut off but doesn't. The codes are p1170 o2 bank 1.. p0300 random misfire... p1173 o2 bank 2... p0171 bank 1 too lean. Changed the coil pack the other day and that wasn't the problem. Unplugged the MAF while running and it ran fine, but the battery light comes on and obviously you can't drive with that unplugged. So, cleaned the MAF and still nothing. Took the air filter out and there is a noise coming from the airbox almost like a popping or blupping sound. Have no idea.Trying to figure out what this is. It's driving me crazy. Can someone please help!!!!
Old 12-30-2010, 12:00 PM
Default Fix the idle problem
Hey, I just fix my 2000 mpv. I had the same exsact problem. The problem is the intake manifold gasket top and bottom. When I remove it there were real bad. I got the diagram of how to take out and install back on. It took me about 4 hours but it's worth to do it your self cuz it's expensive to get done. To cheak it get some carbonator cleaner and spray around the seals and if it changes the idle that's what it is. I know how it is trust me I was real frustrated with this problem.
2000 mpv rough idle/jumping-capture.jpg
Old 01-01-2011, 01:53 AM
Default How To Fix P0300 random misfire codes
How To Fix P0300 random misfire codes in your car
http://www.youtube.com/watch?v=OyvdW...e_gdata_player
I follow this video and it work for me. Copy the link and paste in http search bar
Old 01-01-2011, 11:15 AM
Default diagram how to remove and re-install the intake manifold gaskets
most likely its going to be this
2000 mpv rough idle/jumping-img_1434.jpg   2000 mpv rough idle/jumping-img_1435.jpg   2000 mpv rough idle/jumping-img_1436.jpg   2000 mpv rough idle/jumping-img_1437.jpg   2000 mpv rough idle/jumping-img_1438.jpg
Old 04-02-2012, 02:15 PM
Quote:
Hi Manny,
Thanks for posting the diagrams. Would you happen to have the FUEL INJECTOR REMOVAL/INSTALLATION Diagram? (01-14-16) I want to make sure I do this right.
Thanks again.
SW
Old 07-13-2012, 12:26 AM
Hey, Manny, you seem to know ur car! I have Mazda MPV 2000. Over heated and took it to mechanic. He says it is "oil cooler", a part that has a coroded attachment to a hose, that leads to radiator. He is looking for used part, but new one is $300! But I have never heard of "oil cooler". Have u?
Old 10-22-2012, 08:26 AM
Quote:
Yes, there is an oil cooler, it is where your oil filter screws in. There are 2 coolant lines (from the radiator coolant system) that run to/from in.
Better late than never. Someone might actually need to know...
Old 12-09-2012, 03:05 PM
Default 04 mpv same problem minus check engine light
Hi i have an 04 mpv with the same rough and low rpm idle but no check engine light . Do you think it could be the same problem ?
Thread Thread Starter Forum Replies Last Post
Rough idle and rough running Doggyx Mazda6 8 02-15-2015 10:37 PM
need help with 2000 1.8L rough idle kerad13 Mazda Protege 6 08-15-2009 01:12 PM
2000 Protege, rough idle GopherInWI Mazda Protege 2 03-06-2009 05:44 PM
2000 SP20 Rough Idle Riki Mazda Protege 1 10-27-2008 04:37 PM
rough idle/low idle 03 MPV j_r_42 Mazda MPV 0 08-06-2008 03:41 PM
Tags
2000, bad, codes, diagnosing, drive, engine, fine, idle, idling, idol, maf, mazda, misfire, miss, mpv, park, rough
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
