1991 MPV Headlights turn on by itself when parked
Hi I was wondering if anyone can tell me how to fix this issue. My van headlights keep turning on by themselves and draining the battery when I am away from the vehicle.
When I parked the van and turned off the ignition, they are off. If I come back in an hour, they are on again which is draining the battery.
I just tried starting the van again today. The engine will not turn over. However, there is power because the hazard lights turn on. When I turn the ignition, it just clicks. But I haven't gotten a boost yet to really be able to tell. All I know is that I drove it yesterday and it got me home. In the morning I tried to start it but it was dead. So the lights must have turned on again and drained the battery. But if they were draining the battery, would I still be able to use the hazard lights?
Is this a relay that is causing this? If so, where do I find it on the vehicle to replace it? If it's anything else, what could it be?
Yes if you could please give me detailed instructions, that would be great!
One mechanic told me to disconnect the wires form the DRL module but I believe I already pulled the DRL fuse off sometime ago.
I would appreciate any help. Thank you
