Wipers stuck after arm replacement
Old 01-08-2013, 05:22 PM
Oldschooljohn's Avatar
Default Wipers stuck after arm replacement
Hello everyone I am the proud owner of a beautiful 02 silver Millenia with just 93k (I don't drive a lot). I recently had to replace the driver's side wiper arm. Simple enough, but I made the mistake of cycling the wipers while the arm was off. The passenger side wiper parked with a clunk, and did not move after that, and now even with both arms on nothing happens, just a clunk and they both park and do not move again. The wipers were working perfectly before I replaced the arm, so I am thinking that when I cycled the system with just one arm attached it somehow got "out of synch" with itself (or something) Any suggestions? I'm really stumped here. Thanks much.
Old 01-09-2013, 12:22 PM
tanprotege's Avatar
This is how the wiper assembly looks like:
Probably one of the pivot points has broken.
If you look at in on ebay you can zoom into it:
Google Image Result for http://i.ebayimg.com/00/s/MTIwMFgxNjAw/%24(KGrHqF,!k0E%2BzqzzGO5BP-0)GgumQ~~60_1.JPG%3Fset_id%3D880000500F
Old 01-10-2013, 12:17 PM
Hi, thanks for the feedback. Turns out everything is OK... I just pulled the fuse, removed both wiper arms, put the fuse back in, hit the switch, and it works just fine! The connector to the wiper motor has several wires, I am guessing that there is some kind of "park sensor" that needed to reset itself. Moral of the story... don't cycle your wipers with just one arm attached.
Old 01-10-2013, 08:57 PM
tanprotege's Avatar
Great!
And thanks for the feed back. I learned something.
GhettoRacingKid
08-20-2012 08:11 AM
kalleberg
02-06-2011 03:58 PM
oderaro
03-10-2009 10:25 AM
lax20247
10-23-2007 11:29 AM
merlinknight
09-29-2007 09:12 AM
Quick Reply: Wipers stuck after arm replacement
