Trunk / Gas Door Button - Millenia 2000 - Mazda Forum - Mazda Enthusiast Forums
Thread Tools Search this Thread
Old 06-06-2010, 10:38 AM
Default Trunk / Gas Door Button - Millenia 2000
I'm having an issue with my trunk button not working. I have to slowly press the button for the gas door for it to open. Unfortunately, no matter what I try to pop the trunk, it doesn't work. I use my alarm key to open it, but it's really annoying when I have the engine on. I literally have to shut the engine, pop the trunk using the remote, then restart my engine.
I've checked the fuses and everything seems fine. Has anyone had this issue? And is it an easy fix that I can do myself?
Old 06-06-2010, 02:45 PM
my guess would be the switch. and you have to pull the panel to change it. dont forget to get the 2 push nuts to secure it, they are very hard to remove, and most of the time are not reusable
Old 06-25-2010, 02:51 AM
Cool
1st instead, u do a test .. get the gas door open & then actuate the unlock open, key & remote .. if u hear a "click or clunk) a proper check to the gas door be made ..
Thread Thread Starter Forum Replies Last Post
Trunk(lock/button) mazda 2/demio 2007 kokorico Mazda2 0 03-28-2012 04:23 PM
'01 Mazda Millenia~Trunk buttons won't open trunk. pattyd814 Mazda Millenia 2 06-27-2009 09:35 AM
Button under the gas pedal stuck/broken? elitescouter Mazda Millenia 0 06-16-2009 04:31 PM
88 Trunk / Gas Release Not Working larryb711 Mazda RX-7 8 10-22-2008 02:47 PM
Gas and Trunk Latch is stuck delarzac Mazda3 1 03-09-2007 02:09 AM
Tags
2000, button, buttons, door, fuel, gas, mazda, millenia, open, panel, pop, remote, trunk, trunkfuel, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
