Timing Belt Cover
Timing Belt Cover
How do I change my timing belt cover? It is warped. I had the timing belt changed less than 10,000 miles ago. The dealer put the warped part back on the car and now oil is leaking all over. Can someone help me out? I am pretty handy with tools. I would like to do it myself. Thanks.
if you mean the black plastic cover in front of the engine, that wont fix your oil leak. the timing belt cover does not seal any oil. you probably need valve cover gaskets, or perhaps the bozo's at the dealer neglected to check the cam and crank seals, and they are leaking. if you just change the plastic cover, it will warp again because of the oil.
kinni420
01-28-2013 03:08 AM
baerster
03-19-2010 02:46 PM
mazda99
08-13-2008 04:18 AM
