Tcs, tcs off, and abs light - Mazda Forum - Mazda Enthusiast Forums
Thread Tools Search this Thread
Old 06-10-2010, 07:03 PM
Default Tcs, tcs off, and abs light
I have a 2000 millenia 2.5l. I started it up yesterday and my tcs, tcs off, and abs lights all stayed on. I don't notice a performance difference but I'm unsure of what kind of damage it may cause. Any advice on what I should look for? I have seen some posts that mention a vaccum leak but I'm unsure what that has to do with my braking system?
Old 06-11-2010, 08:20 AM
when the car is started, the control unit does a series of self tests, and these are repeated during the drive cycle. if it sees a problem with the abs, then it disables it. when abs is disabled, traction control(tcs) is too, since the system needs to read off the abs sensors. start with simple fixes, like disconnect/reconnect each sensor. at the same time, examine the pickup end, which might have gotten damaged. however, if there was physical damage, the lites would have immediatly illuminated.
Old 07-11-2010, 03:45 PM
Hello guys, first post here but have already benifited from some info today (Found a bad vacuum line related to a P0304 fault after reading some of the forum).
I am checking the wifes Millenia which is also having the same issue with the ABS and TCS lights. They come on and stay on as soon as I start the car. I have metered both sensors on the front and get transition when moving the tires which indicates to me that is not the cause.
I have also read that the ABS light may come on after a jump start due to a low battery. I have 12.2 on the battery. Any chance that it is the battery or and alternator issue? She has been off work for a while and not driing much since school ended. My next guess would be a harness problem and I have no idea where to check.
Thanks for any help and thanks for the info already provided.
Old 11-22-2010, 09:48 PM
my 2002 mellenia s has similar issue. tcs, tcs off, and abs lights turn on but only when reaching 80mph. do not notice any performance loss and lights shut off after restart. still have not figured it out
Thread Thread Starter Forum Replies Last Post
2001 Milly S - ABS Brake TCS TCS Off lights on no speedo/odo Joeboost Mazda Millenia 7 05-28-2016 02:26 PM
ABS, break light, and tcs light indicators cegar Mazda 323,Mazda 626 & Mazda 929 0 10-26-2011 05:59 AM
1999 mazda millenia S TCS & TCS OFF light stays on and only 2500 RPM max thinhbui Mazda Millenia 6 11-19-2009 01:13 PM
'01 626 V6 - 73K - Abs, Tcs, Tcs Off lights jamcc Mazda 323,Mazda 626 & Mazda 929 2 12-26-2006 02:11 AM
ABS, TCS and TCS Off Light on Mazda 323 luke Mazda 323,Mazda 626 & Mazda 929 1 12-16-2005 10:30 PM
Tags
03, 2010, abs, brake, clean, control, cx7, light, lights, mazda, millenia, mpv, off, rx8, sensor, tcs, traction
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
