Rear brake pads
Old 09-21-2007, 09:12 PM
Richard's Avatar
Default Rear brake pads
Hello all, How hard is it to R&R the rear brake pads on my 97 Millenia? I just had the front ones done two weeks ago and the tech failed to mention that the rear pads were getting a little thin(same thickness as a Kleenex) and I was wondering if they can be replaced without pulling the axle, rear seat, stereo system, etc. Or if they can just slide in like on my old MGB. I broke my ankle a few weks ago and it gets real painfull if I am not careful and bend it in a certain way.
Regards,
Richard
Old 09-25-2007, 06:50 PM
Default RE: Rear brake pads
Richard,
I know that I've done this at least twice on ours. However, I cannot recall if I had to make any tools or such .. (??)
I can only offer what I remember;
The rear brakes are two piece. A) Pad & caliper B) drum and piston
The main rear brakes are your typical pad & caliper. Easy enough to do with a large C clamp and remove two caliper mounts. Although no bleeding is typically required, I always try to "flush" out some of the fluid. (on a dry day)
The parking brake is a drum & piston style and not required for normal operations. Again, I would suggest pulling the rotor off to view the condition of these. If you cannot easily remove the caliper to do this, consider purchasing a new set first. (I've had to maul a rotor off once)
g'luck - they're not that difficult
Old 10-11-2007, 10:48 PM
Very easy. As easy as any I have ever done. regular disc brakes just like the fron. Be sure to get the pads in the right places though. Each pad is marked and I don't think they are interchangeable.
49er
06-17-2015 04:13 PM
Torque
01-20-2015 09:01 AM
grenman
05-29-2009 11:21 AM
trent1059
05-04-2006 10:29 PM
gsxrsrad1000
01-05-2006 11:56 AM
Quick Reply: Rear brake pads
