plugs wet with gas
Did you do both valve cover gaskets? The reason for my question is that if so, it meant you took off the intake manifold, too. Have you checked your connections for the fuel pressure regulator, and the connections to the fuel rails themselves?
I'm assuming you didn't remove the fuel rails and injectors from the intake manifold as that really isn't a required process (they can remain connected to the intake manifold when you take it off and reinstall it).
Hopefully, from the answers you provide, it might give some more details about your issue and what is being experienced.
sixthsense
11-22-2009 08:15 AM
