Motor mounts
Motor mounts
While having my 02 millenia s on jacket stands, I put the car in gear n stepped on the gas pedal. Everytime I pressed the brakes, if I remember correctly, the backside of the motor dropped down noticeably.
I was having noises coming from the front of the car, so I jacked it up. Found some worn bushings n changed them. I checked for any loose/worn out .... joints. I shook ever part of the front end n found nothing else.
Did I miss anything or it most likely is the motor mounts.
