Millenia '96, where can I find the plugs to check the transmission oil level?
So far I've found the engine of my '96 millennia to be leaking. I've found the plug,and the oillevel is very low!
I wanted to make sure the transmission is ok (it's an automatic).
Where can I find the plugs to check the transmission oil level?
The engine seems to be leaking very slowly (tiny leak in one of the axes that extend to the band that connects and rotates the alternator). How would you suggest fixing the leak?, or should I just live like this for a year adding some oil every 2 to 3 months?
Thank you!
Thank you!
