Mazda Millenia 2002 error code P0173
RE: Mazda Millenia 2002 error code P0173
probably one of the many vacuum "tee" fittings is broke, and you are getting air sucked in. this is a labor intensive job. if you have a 2.3, all kinds of stuff will have to come off, depending on which one it is. sometimes, you can actually hear them hissing at idle, where your vacuum will be really high. if you can pinpoint it then, it will be a lot easier. the tee itself is cheap, coupla bucks. but to get to it is BIG bucks.
ha ha. good luck. i have no experience with the 2.5. however, on the 2.3, there is about 40 FEET of vacuum hose, and probably a dozen tees. you might fix it over the weekend. the ENTIRE weekend. LOTS of stuff gotta come off to get to them.
beavis
12-05-2011 09:37 AM
