Ignition key stuck
Ignition key stuck
I am unable to remove the key from the igniton. They key will start the car, but it will not go back past the "ACC". When I remove the ignition fuse, the iginiton can be turned to "LOCK" and the key removed. Is there an easy fix for this?
RE: Ignition key stuck
unbolt the consoul take off the plastic piece from around the shifter look to the right you will see a plastic it is kinda v shape it might be stuck spray some crc on it that locks and unlock if it is not moving free you will never get the key out unless you kill the power.
