Go Back   Mazda Forum - Mazda Enthusiast Forums > Mazda Vehicles > Mazda Millenia
Sign in using an external account
Register Forgot Password?
Search
LinkBack Thread Tools Search this Thread
Old 04-04-2012, 08:05 PM
Default Hoses or The Dreaded Head Gasket?
Ok, so I just ordered a Haynes Manual for my 02 2.5 millenia. I am having issues with over heating. Took it to my mechanic that I have always gone to to have the overflow resevoir replaced(it needed though). Before the replacement, that's where antifreeze was leaking/spewing from. Now, the resevoir is fine, but antifreeze is coming from somewhere behind/around the engine. Upon trying to locate the source of the leak it looked like it was coming from everywhere, because it had covered just about every hose visible. I can't immediately tell if it is a bad or loose hose or the awful thought of the head gasket. I look forward to getting my Haynes Manual, but any help or advice is welcomed.
Register today for free or log-in if already registered to remove this ad!
Old 04-05-2012, 09:32 AM
Quote:
if you had to have someone change the coolant resevoir, a haynes manual aint gonna help you. the coolant resevoir is so simple to change, if you cannot do that job, you need to think seriously about getting rid of the car.
head gaskets dont leak externally, they leak internally. you would see white smoke out the exhaust, and coolant would be disappearing. here is what i would do. first off, clean the engine. then using a coolant pressure test kit, fill the system, and pump it up. now look for leaks. you can rent a kit from places like oreilly's, autozone, etc. if coolant is around the firewall area, i would suspect one of the heater hoses. if it is from the front, i would suspect a crack in the radiator. if the radiator is leaking, the fan will blow the coolant all over the place. and if you cannot change the coolant resevoir, the radiator is way beyond your expertise
Old 04-09-2012, 12:10 PM
Default Service Mnual
milleniatech.net
is a good site for info and heres a link to a 1996 manual thats pretty much the same as yours
milleniatech.net - Documentation
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Med Center Mazda
Pelham, AL 35235
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
