Headlight Adjustment
How do I adjust the headlights on '02 milly? there are holes but i can't seem to find the gears for the low beams...found the gears for the highs...and if rusted is it ok to use pb blaster on them? Thanx
RE: Headlight Adjustment
mine's an 01, i think your's the same, here's how i did mine
look in the back of the low beam light fixture, there's a slot that you can use a phillip screw driver to turn the adjustment, turn left will bring it up, turn right to bring it down, if it seized up then there is a 10mm bolt in there that you can use for the adjustment as well,
STUFFF
02-26-2019 02:38 PM
1996, 323f, 626, 91, adjust, adjustment, adjustments, alignment, cx9, headlight, headlights, mazda, miata, millenia, touring
