Front Jack Point and Stands 2002 Millenia P
New Millenia owner with two basic questions before I change the oil. Where is the front jack point for a floor jack? Where is the best place to put the jack stands? I appreciate the help.
look under the front of the car. about where the transmission bolts to the engine, there is a metal brace going front to rear. the front motor mount also attaches to this piece. i use this brace to jack up the car with a floor jack. it is not exactly centered, so the right side of the car will be lower. i just leave it on the jack when i change the oil. if you gotta use jackstands, there are 4 points to put them, underneath the rocker panels where the seam is. they are marked. look at your owner's manual, it shows them
warrior86
09-15-2012 03:06 AM
