Crazy problem with 95 millenia
I have been having a Crazy problem with my mazda millenia the last two winters....when the Temp outside is under about 45Degrees the Car will start up perfectly and run smooth for 10 to 15 min and then suddenly stall...After stalling it will not crank...coughing like it is not getting Gas....Usually after about 30 min it will crank back up and run fine untill i park it for several hours...and then process repeats...If the outside temp is above 45 degrees it doesnt miss a Lick!!!!!! Anyones help or advice would be Very Apreciated!!!!!!!
