99 millenia turn signal stops working after 20s
Old 02-03-2007, 08:46 PM
mmman's Avatar
Default 99 millenia turn signal stops working after 20s
I bought this car newand it has held up great with no major problems. I don't know why my left turn signal quit working...even if I turn the hazard lights on only the right side work. When it first started the left turn signal would work for about 20s and then stop and now the left turn signal doesn't work at all. Any suggestions on how to fix?
Old 02-03-2007, 09:25 PM
babyhuey's Avatar
Default RE: 99 millenia turn signal stops working after 20s
You have a failed flasher control module mmman. This module gets input signals from turn signals and hazard switch and then pulses voltage to the right or left turn signal bulbs as needed. Module is located under the dash about straight up from where drivers footwell. Seven wires to it with colors Black, Lightgreen, Violet, Black w/ red stripe, Green w/ black stripe, Green w/ yellow stripe, and Lightgreen w/ white stripe. Might be easier to find by turning on right side signals and feeling for the relay/module that is clicking.
OE part number is BG3F-66-830. Pic below is of the flasher module marked with "X"
[IMG]local://upfiles/1377/911CF8EABB20454AA8A07CFB6FDD2CAD.jpg[/IMG]
mazdaidk
06-24-2019 06:00 AM
naellool
12-27-2010 07:01 PM
Rubenau30
08-17-2010 03:25 PM
bleepbloop
01-26-2007 10:17 PM
supermanwithheat
11-25-2006 11:38 PM
Quick Reply: 99 millenia turn signal stops working after 20s
