98 Millenia 2.5 stalling problems
Old 08-06-2009, 10:04 PM
joker247e's Avatar
Default 98 Millenia 2.5 stalling problems
Hello I have a problem I have been trying to figure out. Pretty much I have a stalling problem when im below 1/4 tank of gas, going around big curves makes it start happening it will miss up to about 4k rpm and drop back down pretty much I have to pull over and let it sit and it will fix a while. It also tends to cut off completely if im low on gas and have to brake fast.
Once it has more gas than 1/4 tank these problems stop. I have also had the problem with it not wanting to take gas when filling up since I have had the car. if you fill it with filler in normal position it will spit out gas unless pumping really slow. But if I tilt the filler at 65 degrees i can pump gas normally.
One last note when the car misses there is a strong smell of gas that comes in the car. it only has 65k miles on it . I also tried disconnecting the egr sensor since I have read alot about that messing up. Also there is no CEL light for any of this. So far I have just tried to keep the car filled over 1/4 tank. I have seen alot of issues with stalling and sputtering on this forum but none that has to deal with the amount of gas in the tank. Any help will be appreciated
tronno
04-24-2009 08:03 PM
Jap Joloppi
02-14-2009 04:45 PM
2002Mazda
03-31-2008 03:41 PM
ccannon222
12-15-2007 04:50 PM
PHILLY061500
03-07-2007 06:28 PM
Quick Reply: 98 Millenia 2.5 stalling problems
