02 Milly S Knock Sensor circuit....?
I'm trying to trouble shoot a P0325 CEL code for an 02 Milly S. I have the Alldata TS guide but I don't have a diagram describing where the connections are that I need to check. I need to know where the PCM and the X-20 connctor are located. Can anyne help?
x20 is position 2k on the pcm. it is a grey/white wire. it appears to also be on the main harness in the engine bay, going to the intake air temp sensor on the compressor. good luck.
Thanks for the response. It's a mute point. I bought a new knock sensor in anticipation that it was the problem but I wanted to make sure it wasn't a wiring problem before ai tackled such a project. I connected the new KS to the harness and then grouned it out and and CEl went out. So, it looks like I'm going to have a little work ahead of me. I still have 8k left on my warranty so if that sort of thing is covered, I'll let my mech do it. He could use the business. Thanks again!
sandman8002
12-07-2006 06:25 AM
