Go Back   Mazda Forum - Mazda Enthusiast Forums > Mazda Vehicles > Mazda Miata
Sign in using an external account
Register Forgot Password?
Search
LinkBack Thread Tools Search this Thread
Old 05-01-2012, 11:52 AM
Default Removing Cat
What are the general thoughts on removing the exhaust catalyst ?
thanks,
gander10
Register today for free or log-in if already registered to remove this ad!
Old 05-01-2012, 01:04 PM
shipo's Avatar
Quote:
thanks,
gander10
Personally I'm fond of breathing air which is as clean as possible; for the sake of the rest of us you share this planet with, please leave your catalytic converter in place.
__________________
1998 Audi A4 2.8 Quattro 5-Speed
2009 Mazda3 i Touring Value Edition 5-Speed
2012 VW GTI 2-Door 6-Speed
Old 05-01-2012, 01:34 PM
2004 Mazda Mazda3
More trouble than its worth in most cases. They are even trying to find ways to clean up race car exhaust.
If you are driving on the street, keep the cat. Your CEL and state inspection station will love you for it.
__________________
"Like" us on Facebook https://www.facebook.com/pages/Mazda...77350618947016
"There is no tool you can buy that will replace experience." - Josh Mills, C.K.DeLuxe/Koolhouse Publishing
Old 05-01-2012, 01:56 PM
2006 Mazda Mazda6
Hollowing out a catalytic converter or replacing it with a test pipe or straight section of pipe is a violation of Federal Law punishable by fines in excess of $25,000 and/or jail time for both the vehicle owner and the person doing the work.
Removing a catalytic converter will result, at most, in 5 HP in power improvement. However, hollowing out a catalytic converter will cause resonance problems. The symptom is most often seen as a hesitation, popping, or backfire at or about 3,200-3,500 RPM. Upon hard acceleration, the engine will appear to cut out for a split second as RPMs drop and a split second later recover and continue past 3,200-3,500 RPM. Additional symptoms are a loud and continual popping sound when the vehicle is allowed to decelerate under load and a whooshing sound that is delayed from or following the engine speed. This is due to the open chamber within the hollowed out catalytic converter case. It loads up and releases pressure in the exhaust system that acts almost as a capacitor. The open chamber allows the formation of standing waves within the chamber which reflects back toward the engine and causes the hesitation and miss in the RPM range.
Above from: ISUPAGE; Performance Exhaust System Basics
your factory catalytic converters are robbing horsepower from your engine by creating a huge restriction and excessive heat in your exhaust system. To combat that, aftermarket parts companies have come up with test pipes and high flow cats for many popular applications. companies like Berk Technology have streamlined their high flow catalytic converters to a point where they have been proven to flow exhaust gasses up to 87% as efficiently as their test pipes, which is only 1.3 horsepower less per 10 horsepower gained.
Above from: Test Pipes vs. High Flow Cats |
I would get a hi-flow cat 1/4" bigger than stock with an exhaust pipe 1/4" wider than stock to maximize flow. Make sure the exhaust before and after your cat is also 1/4" wider as well. Sound, flow and power should be realized. On my 3.0 litre V6 the stock exhaust is 2.25", mine is 2.5" and the single flow part. Any bigger would negate flow. Check out Magnaflow.
http://www.magnaflow.com/wideopen/performdata.asp
__________________
2006 Mazda 6, 3.0-V6, 6 Speed ATX, 61000 km
MODS:24mm Progess Rear Sway, 1.5" Drop Front, LED int lights, K&N SRI to CAI with engine baffle, Steeda 1/2 Spacer, Battery insulated, Solar Panel, Pre-Cat Back Custom Exhaust to 2.5"Magnaflow Main Cat, MazdaSpeed Cat Back, 2V Hi Voltage Ign Coils, Water Shield, HiD Low Beams, 2 15" Subs, Extra Grounds, External Tranny Cooler, Tinted Windows, 180 T-Stat, Lucas Engine Oil, B&G Tranny Oil, Cut Throttle Shaft, Chrome Strips
Tags
3200, 3500, cat, catalytic, cats, cuts, eliminating, forums, mazda, miata, remove, removing, rpm, stumble, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Med Center Mazda
Pelham, AL 35235
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
