Go Back   Mazda Forum - Mazda Enthusiast Forums > Mazda Vehicles > Mazda Miata
Sign in using an external account
Register Forgot Password?
Search
LinkBack Thread Tools Search this Thread
Old 06-05-2013, 09:56 PM
Default miata not cranking
I have a 1993 Miata that I bought two years ago. It ran like a champ for months and then began have problems starting when cold, not even turning over. I have replaced the starter twice, cleaned and replaced the ignition switch a couple times, installed a new clutch switch and the battery is good. Dash and head lights work fine and the starter cranks when connected directly to the battery. I do not know if there is an anti-theft device installed.
Please help with ideas on where to go next in this adventure
thanks
Register today for free or log-in if already registered to remove this ad!
Old 06-06-2013, 10:44 AM
tanprotege's Avatar
1998 Mazda Protege
'roo:
Have you had a chance to do some voltage drop testing in the starting circuits?
Can you find out if it gets fuel and spark when you shortcut the starting circuit?
Have had chance to check the crank position sensor and the cam position sensor?
There should be a blinking light somewhere if it has an anti theft devise.
I am not sure if I am of much help but voltage drop testing will let you know where the juice goes and where it stops. That is the key to closing in on the problem.
Here is an article on voltage drop testing: Voltage Drop Testing
Good luck, mate!
__________________
TanProtege
"It is important to know the difference between 'precise' and 'accurate' even if you are neither!"
Who is that person in the avatar?
'05 Pontiac Vibe
'00 Ford Contour SE, 2L
'98 Mazda Protege, 1.5L 5 speed
'97 Mazda B 2300, 5 speed
Previously owned:
'03 Ford Windstar, '94 Ford Aerostar XLT 4L, '89 Geo Prizm, '86 Mazda 323 DX, 5 speed, '86 Chevrolet Cavalier , '81 Mercury Capri I6, VW 1302, Peugeot 304, VW 1300, BMW R26 (motorcycle), Hercules MK 4 (moped)
Tags
1993, 91, 94, 97, backfiring, crank, cranking, miata, not, starter, starting, triuble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Med Center Mazda
Pelham, AL 35235
Internet Brands, Inc.
