Miata 1999 Low beam does not work
Old 04-28-2006, 07:08 PM
mazdafan's Avatar
Default Miata 1999 Low beam does not work
Dear friends:
I love my Miata, but recently I discovered that the low beam is inoperational on both sides. Only the high beam works, when allowed to work.
Best regards
MK
Old 04-28-2006, 09:46 PM
Default RE: Miata 1999 Low beam does not work
Replace the bulbs. There are high and low beams in each bulb. It is possible for either setting to blow leaving the other intact.
Old 04-28-2006, 10:24 PM
babyhuey's Avatar
Exactly said bluebomberx. The low beams are usually on 95% of the time when headlights are used so of course they would tend to be the ones that burn out first. Possible that headlight switch is faulty but much more likely to be a bulb. And much cheaper too If bulbs fail to get the low beams up and running then a headllight switch would be the next place to look. Any fuse that would blow would not take out both low beams only but would instead take out low and high on one side or if the main headlight fuse blew would take out all.
Old 04-29-2006, 02:35 PM
mazdafan's Avatar
Thanks. You are right on the money. Both lamps were fused!
Best regards to all.
M Khan
Pochi09
08-03-2010 05:11 PM
mazda guy
04-27-2009 07:48 AM
alpharat
06-10-2007 03:35 PM
gsxrsrad1000
05-02-2007 11:37 PM
colmax
06-12-2005 03:50 AM
Quick Reply: Miata 1999 Low beam does not work
