'03 Miata, Replace Fuel Filter
RE: '03 Miata, Replace Fuel Filter
Diagram below shows how to release the fuel line clips. Once line is off then transfer the little clip piece that stays on the filter back into the fuel line. You can depressurize the system by removing the fuel pump relay under the dash and allowing to run untill engine stalls but is really not necessary. Just hold a rag around the fuel line connection as you are disconnecting so it will not spray on you.
DjSlickSVG
01-27-2014 11:29 PM
Variety=Spice
10-11-2007 11:14 PM
