Mazda Forum Help & Suggestion Center Forum for members experiencing problems with the board or those who have suggestions to make the forum better.
Mazda preacy speort, petrol losing fuel and jerking
Old 06-25-2016, 03:57 PM
Dmaher1878's Avatar
Exclamation Mazda preacy speort, petrol losing fuel and jerking
I have a mazda premacy sport, 2ltr petrol, which
Is using a lot if petrol.
The car jerks she. Start to move, the gear stick also shakes, until I build up speed. The rev counter goes above 1500 when turning the engine on
I we told it could be the maf sensor, and to unplugg it, when engine is running. I was then advised if the engine continued to run (which it did), then it's a bad sensor??
Recently it's had a new fuel filter, New plugs, it has 90,000 on the clock
Old 06-26-2016, 06:23 AM
Could be a bad MAF, could be a bad ignition coil, could be split intake hose.
Old 06-26-2016, 10:35 AM
Dmaher1878's Avatar
Is it correct, when you disconnect the maf ,and the engine continues to run, which it did , that sensor is bad??
Previously had a code to replace solenoid valve, I have replaced thy, and the fuel filter. Another code has popped up0102??
CADDMaz
10-28-2013 02:24 AM
neo123
09-07-2010 01:59 AM
marvdog187
10-21-2007 12:55 PM
totalclimax
08-04-2006 10:50 PM
nastynate
06-23-2006 01:03 AM
Quick Reply: Mazda preacy speort, petrol losing fuel and jerking
