Right rear door won't open
Old 08-02-2014, 11:12 AM
2009mazdacx9's Avatar
Default Right rear door won't open
Had an issue with the window not going down all the way on the right rear door. I decided to remove the door panel. When I did I found that a piece of foam had come loose and block the travel of the window. I was able to make the foam fall to the bottom of the door and the window work properly again. I re-installed the panel and shut the door. Now the door will not open, from the outside handle to the inside handle, nothing. I got the door panel loose and I'm trying to figure out what to do to get the latch open. ANY IDEAS??? Help!!!!
jbriss
12-28-2011 03:47 PM
arnie59
11-17-2010 07:30 AM
Xato
03-06-2010 08:41 AM
TA/Hawk
12-30-2009 04:41 PM
packerfaninva
03-02-2008 03:14 PM
Quick Reply: Right rear door won't open
