What do I need to play Ipod thru aux in console?
RE: What do I need to play Ipod thru aux in console?
I have same problem, my dealer said I need to purchase the 30 pin cord with jack on other end. Guy at radio Shack said dealer is wrong a standard 3.5mm x 3.5mm male to male should work, but it doesnt. My media button does nothing when I push it.
What did you figure out?
Thanks
Thanks
Press your media button untill you see "aux" on the readout... from there... make sure the volume is up on both the car stereo and on your ipod... you do NOT need the 30 pin connector... all you need is the male to male as mentioned...
Just got my 08 CX-9 last night. Couldn't sleep so decided to check out all the features on the car. Plugged in my iPod with a 3.5mm plug. Didn't work at first. Started reading the manual, the quick tips guide....nothing. For some reason, something must have clicked in or I must have hit Ctrl-Alt-Del and reset something but it started working...
What options do you have? Do you have Navi, Bose, and/or Sirius? There are some incompatibilities that may not allow you to use the Aux port. I have Navi and Sirius and have not been able to get my Auz to work. The dealership told me that even the specil module would not work.
Craig
Craig
CraigNAVI disallows the iPod integration module from working. Just can't do it. That's just how they designed it, and I don't know why. I just know I've dealt with annoying salesmen who have sold the iPod module to a customer buying a car without doing their research, and I learned the hard way by having to take the iPod module back out. In terms of having Sirius satellite installed, on anything before some late '08 models and '09, the harness for the Aux port has to be unplugged so the Sirius harness can be plugged in. If you want to have both, ask your dealer about a Switching Box that can be installed.
