Horn fuse keeps blowing
Hi, I have a 2010 CX-9. Last night I discovered my horn is not working. I checked the fuse and it was bad. I replaced it with another 15A fuse, it it blew right away. Does this mean there is a short somewhere? Could the horn relay be bad?
Might be related, but when we get a really heavy rain or go through the car wash, the alarm/horn will start going off seemingly randomly, like some water got in somewhere. After a while it clears up. But, I havn't washed the vehicle and we haven't got any rain recently. I had seen an issue with CX-9 with moon roofs having issue with drain clog causing water to penetrate BCM. My vehicle doesn't have moon roof so don't think there is an issue there.
Thanks,
Scott
Thanks,
Scott
follow-up:
I picked the high horn and disconnected it. When I tried to honk the horn, still no sound but the fuse did not blow. Connected the horn, then when tried to honk the horn, fuse blew.
Two follow-up questions:
1) Does it make sense that the low horn doesn't make a sound when high horn is disconnected?
2) Do I need to just replace the high horn?
Thanks,
Scott
Thanks,
Scott
bs24
01-06-2007 06:43 PM
