Mazda CX7 DPF reset without MMDS tester
Old 08-22-2015, 04:12 AM
Steve09Cx7's Avatar
Hi,
You don't load it onto your ELM. You go to forscan.org and download the software and install it on your computer. Then plug the ELM into the vehicle. Connect it to your computer via usb or wifi depending which one you have. Open forscan on your computer, make sure it's looking at the correct port and press connect!
I also have the iPhone version so I can connect to the car from my phone while driving. (I have the wifi ELM).
Old 08-23-2015, 10:12 AM
b100068's Avatar
Default Thanks Steve for reply
Originally Posted by b100068
steve can you give more info on download from Forscan.org and how you loaded it on to your ELM Thanks
Just to double check is that forscan.org ( no forscan.com) download is beta 2.1.14 2014-01-25 reset dpf learned values? Thanks
Old 08-31-2015, 11:05 PM
wayne_cx7's Avatar
I need to extinguish my flashing dpf lamp which is definitely on for a service reminder, any ideas if this can be done via an OBD2 scanner or without please?
Old 09-01-2015, 04:18 AM
Steve09Cx7's Avatar
Default You got it
You can just download the latest version of you want. 2.2.5.
Pretty sure from memory that's what you do. Hit the reset dpf values and it then steps you through what to do.
Old 09-01-2015, 04:19 AM
Steve09Cx7's Avatar
Default You'll an obd2 scanner
$25 off eBay
Old 09-05-2015, 11:41 PM
Warren Perkins's Avatar
Default Quick Question
Guys one thing, whilst conducting the forced DPF Burn does the connector need to remain grounded? Also is this connector the same as the reset oil change, ie is this connected to the ECU as in the link provided on page one of this thread https://drive.google.com/file/d/0B8A...it?usp=sharing, because my Mazda CX7 2.2l MZD CD has a two port connector as apposed to a six port connector.
Old 07-19-2020, 01:50 PM
Kevin Mason's Avatar
forscan.com is no more. Is there another site?
Old 07-20-2020, 07:20 AM
Steve09Cx7's Avatar
it’s forscan.org not .com
Old 08-21-2021, 05:53 AM
Default Timing chain
Just to let you know a flashing DPF is also an indication that the timing chain is loosening. This is what happened to me.
jefegusto
04-18-2014 12:35 PM
rmfinnie
06-25-2013 06:02 AM
rmfinnie
04-17-2013 07:13 AM
rmfinnie
Intake, Headers and Exhaust
04-17-2013 07:12 AM
AITRacing
07-19-2007 07:56 PM
Quick Reply: Mazda CX7 DPF reset without MMDS tester
