"Tire Pressure: Increase Pressure" message wont go away.
I got this message of Friday (8/23/13) afternoon. I visually checked my tires and they all seemed okay. I went to the gas station and set the pressure on the air machine to 34PSI. It was a hot summer day and guess what, I deflated the tires from 40PSI to 34PSI!! I reset the TPMS switch. The message was still there.
Realizing my mistake, I went back and inflated the tires back to 40PSI. I reset the TPMS switch. The message was still there. I drove a while on Saturday thinking it will take a while for the warning message to disappear. Nothing. I woke up early today (Sunday) and wen to the gas stations and set the PSI for all the tires to 34PSI (It was 57 degrees) so the tires were cold. I reset the TPMS switch. The message was still there!!
Given that the tires looked fine when the message first appeared, I am led to believe maybe this message had nothing to do with the tire pressure in the first place. I am calling the service shop tomorrow Monday. I will keep you posted but if anyone has any idea what is going or what I should do, please share.
Thanks.
Thanks.
I don't know how the tribute is set up but there is a pressure monitor on my Windstar. It compares the wheel speeds of the 4 wheels. When one of them spins faster than the others over some time the "check tires" goes on. After inflating the tires I need to manually reset the monitor.
In addition there is a system calibration program. Once I have that "on" I need to make 2 tight loops going left followed by 2 loops going right. That gives the computer the base line to calculate normal wheel speeds.
When the tire pressure drops that wheel will spin faster because the effective tire diameter shrunk.
Check your manual. I bet it details your system.
RESOLVED - Just as I suspected, the warning light had nothing to do with TPMS. It was the message displayed to remind me to go check my tire pressure. I had set it for reminder every 1 month and by default it reminds you 15 days before so I was getting the warning in just 14 days. This is why I was confused. Needless to say, I turned off the reminder.
Thanks
Tanzanite
08-13-2013 12:19 PM
dabossmazda
07-23-2009 03:23 AM
