CX5 trans fluid
The air filter and box doesn't have to be removed when changing the motor oil. So changing the ATF fluid isn't quite as easy as the engine oil...
trans filter
2014 CX5
took off 2 undercovers and got access to trans drain bolt and I can also loosen fill/check port from underneath. I see that the trans pan is removable and also rock auto sells a replacement filter for this vehicle. Has anyone dropped the pan and replaced the filter on this car?
2014 CX5
Yes.
https://www.mazdas247.com/forum/show...ATF-Drain-Fill
