Sponsored by:
Sponsored by:
2013 CX5 Brake Caliper
Old 05-24-2015, 08:28 PM
flipper331's Avatar
Default 2013 CX5 Brake Caliper
Hello All, does anyone know the part # and or where I can get a pair of Rear brake caliper springs for the emergency brake?
thanks
Old 05-26-2015, 10:20 AM
paris1's Avatar
How about a Mazda dealer for both?
Old 05-26-2015, 01:16 PM
flipper331's Avatar
They were no help, dealer stated, that in order to replace the removable spring, a new caliper has to be installed, cause mazda doesn't sell the spring separately, nor willing to give a part number for it.
Old 05-26-2015, 05:09 PM
paris1's Avatar
It sounds like there may not be a PN for the spring. Here's a blow-up of the rear brake assembly. REAR BRAKE MECHANISMS. Fits: Mazda CX-5 | Jim Ellis MazdaMaybe it will help. I'm not sure which spring you're referring to.
Old 05-26-2015, 08:00 PM
flipper331's Avatar
Thanks for the Picture of the assembly, its the Spring in the upper left corner its to retract the emergency brake arm. Doesn't show a P/n. Very surprised that there isnt one, guess it a way to make $$ for a small part.
Old 05-26-2015, 11:24 PM
paris1's Avatar
You might try an internet search of junk yards. What happened to the originals?
Old 05-27-2015, 12:00 AM
flipper331's Avatar
the original ones are very week,
Old 05-27-2015, 05:12 AM
How old is your CX5? Is it still under warranty? What makes you think the spring is weak?
Old 05-27-2015, 08:32 AM
flipper331's Avatar
mazda said not under warranty, I feel they are weak, is because the emergency brake arm does not fully retract, even when cable is disconnected, so that leaves out binding of the cable run.
Old 05-28-2015, 04:22 AM
De-adjust the handbrake cable.
Remove the caliper & pads.
Wind in the piston, get someone to slowly press the brake pedal until the piston moves back out about 15mm / 1/2 inch.
Wind the piston back in.
Reassemble.
Pump the brake pedal 50 times.
Check where the lever sits.
0tibs
12-09-2007 04:47 PM
CARLOSPEED
11-28-2007 01:39 PM
Boscatman
01-12-2007 12:54 AM
Boscatman
06-05-2006 11:39 PM
the_gray_mazda6
26
06-04-2006 05:41 PM
Quick Reply: 2013 CX5 Brake Caliper
