Might have an oil leak?
Old 01-04-2006, 11:43 PM
Alucard's Avatar
Default Might have an oil leak?
I am afraid that I might have an oil leak on my 92 1.6 liter 4 cly 323. I mean if it is a leak it doesn't seem to be coming from the oil drain plug or the filter. I am afraid that it might be higher up.
What should I look for and where should I look for a leak?
I really hope I am not having a leak, but I can't be sure because its only a small amount I saw. But I want to make sure.
Also I need to get some new splash gaurds for my 323 any one know where I could find some for cheap, I am hoping I can just find them some where online. I hope.
Thanks, Aaron
Old 01-04-2006, 11:55 PM
babyhuey's Avatar
Default RE: Might have an oil leak?
Many places can leak oil but most common from the valve cover or front camshaft/crankshaft oil seals. Oil pressure sender might also be leaking but they usually leak quite a bit. Try to isolate where on the engine it is from by putting a piece of clean cardboard under car overnight and then mark where front tires are in relation to cardboard. Back car off in the morning and should show up.
Old 01-05-2006, 02:32 AM
Alucard's Avatar
Well the leak is coming from (if you slide under the front of the car) right behind the oil pan, it looks like it had dripped down. I am thinking it is coming from the valve cover.
I will get some cardboard under there like you said and see what happens.
Thanks Babyhuey.
Old 01-05-2006, 04:45 AM
babyhuey's Avatar
If it is coming from the valve cover then you should be able to see the leak from above. How much is leaking out? The oil pressure sending unit is in the same area as the oil filter but only higher up. A leaking oil sender will usually drip quite a bit if engine is running but may only be a little if just starting to fail.
Jessev
08-06-2021 10:03 AM
Hawx20
03-31-2013 10:31 PM
hairyg
11-07-2011 09:37 PM
JJohnsonAZ
04-09-2011 07:18 PM
the_gray_mazda6
04-03-2006 01:13 AM
Quick Reply: Might have an oil leak?
