Mazda 626 fuse box diagram
Hello,
I'd like to find a fuse box diagram for a 1997 mazda 626, 2.0 4 cyl, automatic transmission. It's because both my dashboard lights and my tail lights are out and I read on another forum somewhere that it's probably a fuse with a bad connection. I just don't know which fuse it is I should look at...
Thanks a lot!
Bart
Thanks a lot!
Bart
RE: Mazda 626 fuse box diagram
It would probably be the fuse labeled TAIL in the under hood fuse/ relay box. Diagram of which one should be on the underside of the box cover. If no diagram then you should see a series of slots near the lower edge that should accomodate 4 regular blade type fuses. There should be a 15 Amp blue one in one of the slots and the other three should be empty. That 15 Amp is the TAIL fuse.
sonnybungay
09-20-2007 01:39 AM
Skinner
04-16-2006 09:13 PM
