INCREASING FUEL SMELL???
Old 09-07-2006, 01:05 PM
STARBUCK's Avatar
Default INCREASING FUEL SMELL???
How's it goin gang...I've been noticed an increase in a fuel smell when driving lately. I went to a servic station they could not smell it they acted like I was crazy, but the smell is getting more noticeable. Any suggestions? I have a 1998 626 es the car seem to run fine but the smell becoming unbarable.
Old 09-07-2006, 01:10 PM
sstlaure's Avatar
Default RE: INCREASING FUEL SMELL???
Figure out where it's coming from. I believe your gas tank is actually under the rear seat cushion, it's possible a fuel line has rotted out and needs to be replaced. (I had that happen on an old 4Runner I had)
Old 09-08-2006, 04:30 PM
STARBUCK's Avatar
ALL I CAN TELL IS THAT IT IS COMING INTO THE PASSENGER COMPARTMENT WHEN I DRIVE. ANY SUGGESTIONS WOULD BE GREATLY APPRECIATED. THANKS FOR THE QUICK PREVIOUS RESPONSE.
Old 09-09-2006, 12:16 AM
bkey71's Avatar
Here is another way to help check. This procedure will keep the electric fuel pump running while the engine is off. First locate the data connector which is located under the steering column area on the dash, it will be plainly visible. It is a rectangle shape. Next install a jumper wire between the two spots on the pic and then turn the key to the on position but not running. You should now hear the fuel pump humming in the gas tank. This will pressurize the fuel system to help find any leaks. Let it run a few minutes and see if you can observe any gas dripping from somewhere on the car then you'll know where to start.
[IMG]local://upfiles/1828/4CACC1F5D5CF4224BD4919A979072833.jpg[/IMG]
Old 09-09-2006, 01:41 AM
STARBUCK's Avatar
Thanks I'll give it a try, I'm not the best mechanic but it sounds easy enough.
Old 09-11-2006, 04:56 PM
tell your passengers not to smoke in your car!!! that would not be good. I was just reading about cars that had engine fires in my town. probably from the extreme global warming changes and unmaintained vehicles.
Old 09-11-2006, 05:40 PM
sstlaure's Avatar
ORIGINAL: Chronicle
I hope you're joking about global warming changes causing cars to catch fire....Unmaintained vehicles I would believe....
Old 09-12-2006, 04:22 AM
STARBUCK's Avatar
HEY GUYS I THINK I FOUND THE PROBLEM, IT WAS A LITTLE SUCTION HOSE THAT WAS NOT CONNECTED IT SMELLED LIKE GAS SO I THINK THAT MAY HAVE BEEN THE PROBLEM. I GUESS I HAD TO ACTUALLY GET MY BUTT UNDER THE HOOD AND LOOK. THANKS FOR THE INPUT...THIS SITE IS GREAT. THERE WAS ALOT OF EXCELLENT SUGGESTIONS. STAY TUNED....
Old 09-16-2006, 12:19 AM
STARBUCK's Avatar
UPDATE: NOW AFTER I SOLVED THE FUEL SMELL PROBLEM, NOW MY 626 HAS A PROBLEM STARTING. IT'S LIKE IT HAS TO TURN OVER A LOT JUST TO GET STARTED LIKE IT'S FLOODED OR SOMETHING. IT SEEMS LIKE IT WOULD BE SOMETHING SIMPLE....IT USED TO JUST START RIGHT UP. THE PEOPLE AT AUTO ZONE "SAID IT MIGHT BE AN EVR VALVE OR THE CATALITIC CONVERTER IS PLUG OR NEEDS TO BE REPLACE. ANY SUGGESTIONS WOULD BE APPRECIATED.
Danuche99
05-12-2015 06:52 AM
Mooseypants
10-20-2010 03:29 PM
djeldridge
08-29-2008 10:23 PM
hkalirah
01-17-2007 06:52 PM
STARBUCK
10
11-25-2006 11:35 PM
Quick Reply: INCREASING FUEL SMELL???
