Mazda 323 headlight problem
Old 09-20-2019, 06:12 AM
Norman88's Avatar
Default Mazda 323 headlight problem
The lower is the old, the upper is the new fuse I bought
I just bought a 1995 Mazda 323 sedan a good month ago. The entire headlights just doesn't works, so I suspected de fuse gone out. I changed it, but still noting. I checked the bulbs, vut they seems ok.
Anyone has any idea guys?
Old 09-20-2019, 09:42 PM
Are you getting power & earth at the headlight bulb connector?
Is the headlight relay clicking when the lights are turned on? Are you getting power, earth & trigger feed to the headlamp relay/s?
Old 09-25-2019, 12:49 AM
Norman88's Avatar
The relay clicks when I turn on the position lamp. I guess it means its ok, but is that same raley works the other lamps too?
Old 09-27-2019, 05:01 AM
Have you checked for power & earth?
Old 09-27-2019, 12:22 PM
Norman88's Avatar
Yes, they seem ok. I guess the last chance must be a cable problem
Old 11-01-2019, 02:03 AM
Kami's Avatar
Check you fuses from inside, not outside.
Elethim
03-11-2014 10:15 PM
alex_22289
05-23-2011 12:23 AM
Angela needs help!
10-28-2009 03:58 PM
laila01
03-09-2007 03:25 AM
diamondpack
11-14-2006 10:52 PM
Quick Reply: Mazda 323 headlight problem
