626 with a stuck CV joint
Old 12-02-2006, 08:02 PM
mwindt's Avatar
Default 626 with a stuck CV joint
I have a 1997 626 that I am trying to replace the passenger's side cv joint. It came out of the hub without a problem, but the half shaft side will not budge. I have tried heat, penetrating fluid, hammers, pry bars, and the special slide hammer tool.
Can anyone offer any suggestions?
Thanks!
Old 12-02-2006, 10:41 PM
bkey71's Avatar
Default RE: 626 with a stuck CV joint
I am confused how you have worded most parts of the question. The "half shaft" is the complete assembly. If the axle is free of the hub, all you have to do is use a prybar to pop it loose from the transmission. This is considering that you have broke apart the ball joint from the control arm. The "hub" is where the brake rotor is located. If you are using heat on the trans side of the axle, you can create more problems. I never knew of any special slide hammer tool to remove the axle from the trans. Is it the inner or outer joint that is stuck?
Old 12-02-2006, 11:43 PM
mwindt's Avatar
Haha, sorry. On the passenger's side the half shaft/jack shaft extends from the transmission to the mount on the block and then the drive shaft slides onto the jack shaft. This is where the drive shaft is stuck.
Old 12-03-2006, 12:16 AM
bkey71's Avatar
I bet its stuck on the circlip. I have had to use two prybars opposite of each other to apply equal pressure to the axle to remove it in the past. Here is a pic of the intermediate shaft with the circlip in question.
[IMG]local://upfiles/1828/445C64A9CA0D4E80B8955F0941908B79.jpg[/IMG]
Old 12-03-2006, 01:20 AM
mwindt's Avatar
Those c-clips work very, very well. I am not sure how to get the two pry bars on the joint there, there is not much to pry against. I am almost ready to replace the jack shaft too...
oderaro
03-10-2009 10:25 AM
davedele
05-11-2007 08:16 PM
fordman
08-27-2006 11:27 PM
duluthmazda
07-19-2006 06:17 PM
styxzx
07-13-2006 10:15 AM
Quick Reply: 626 with a stuck CV joint
