2000 626 possible PCM trouble
Car stalled while driving. Verified fuel pump will create 45 psi, tested relays, and verified all fuses good. Tried two different code readers and they will not communicate with the PCM. No spark and no fuel pressure with key in crank position. Any suggestion?
I have been using the free repair guides through AutoZone. I see the imobilizer in the wiring diagram but have not found a diagram with its location. Is it integrated into the PCM or a stand alone device. The wiring diagram also indicates that some cars do not have an imobilizer. How would I know if this car has one?
If fitted, it will be mounted on or beside the steering column.
Its rare to have a 626 thru the shop now days. I know on the Mazda 6 there is a red immobiliser light that flashes when the key is off, not sure if 626 is same.
themagicdude88
01-18-2012 07:04 AM
aa225
01-26-2010 02:22 PM
