1999 Mazda 626, disabling the alarm
Old 09-22-2005, 07:46 PM
kirk's Avatar
Default 1999 Mazda 626, disabling the alarm
I just recently purchased a 1999 Mazda 626 and would like to disable the alarm system. This alarm system begins a 15 second count down once you open the door. If you don't turn the car on in time it will go off.
The car had no owners manual and am unable to find what to do.
If anyone knows what fuse to disable I would appreciate it. Also, are there other things on this fuse? Thank you for your time.
Old 09-23-2005, 03:02 PM
Default RE: 1999 Mazda 626, disabling the alarm
I was having trouble with my alarm too. I read about a toggle switch thats supposed to disarm the alarm but mine didnt work. To disable mine I had to disconnect the wires going in and out of the alarm box under the dash on driver side. If u take the under side of the dash apart and see a toggle switch follow the wire and jus disconnect all the wires. Sorry if this sounds redundant, I'm car stupid so I did my best to make sense.
Old 09-23-2005, 11:07 PM
bkey71's Avatar
Is this an aftermarket alarm? If so it should not be hard to find. Just look for the alarm module and disconnect the "brain" of the system. If it has starter kill, you will have to reconnect the starter wiring back to original, or the car may not start. It just depends what kind of alarm brand it is and how many systems are incorporated. I used to have to take many alarms out of our used cars due to malfunctions or no key fobs.
Old 09-23-2005, 11:37 PM
babyhuey's Avatar
Easiest way is to open the hood and look for the hood switch. Should be at the front right corner area. Disconnect the switch connector and see if system will not arm as it normally would. If it still does, then short the two wires together and try again. Basically you are fooling the CPU which controls the alarm system into thinking that the hood is always open and so it will not arm itself.
Old 10-06-2016, 11:02 PM
lennyt's Avatar
Hi Babyhuey - my 2000 mazda 626 security has activated and the engine is disabled - not recognizing the original key. will the hood switch trick work on my situation too?
Old 10-06-2016, 11:07 PM
lennyt's Avatar
I have found the factory immobilizer on my 2000 Mazda 626 which has disabled my engine (not recognizing the original key). do you know which wires on the immobilizer i have to reconnect or jump or cut?? thx!
Old 10-07-2016, 05:01 AM
You cant bypass the factory immobiliser. Do you have a spare key?
Old 10-07-2016, 08:40 AM
lennyt's Avatar
no - no spare key unfortunately
Old 10-07-2016, 09:20 PM
You are in the poop.
Tow it to the dealer, they with supply, cut & code two keys ( 2 keys are required)
Rubehayseed
04-18-2014 06:17 PM
jellofishi
01-25-2012 12:19 AM
ptrshah
03-07-2011 05:58 PM
kblakus
09-22-2010 03:36 PM
redline808
03-22-2007 02:27 AM
Quick Reply: 1999 Mazda 626, disabling the alarm
