broken ring
Old 12-29-2016, 05:32 PM
greasegeek's Avatar
Default broken ring
is it possible to remove pistons in a 1.8 from below without removing the engine? thanks.
Old 12-30-2016, 09:14 PM
Technically yes, but alot of effort. You would need to remove the transmission, then the sump, then the crankshaft. or remove the sump, then the cylinder head.
Old 12-31-2016, 03:09 AM
greasegeek's Avatar
Thanks, I want to avoid pulling the engine and head. why does the head have to come off in conjunction w/ the sump? will the pistons come out from below? the crank can be removed from some fore/aft engines (ford, dodge, Chevy), but I've never heard of it on an engine mounted cross-way.
Old 01-01-2017, 04:48 AM
The Pistons are bolted to the crankshaft and it bolts to the transmission.
louzda
06-17-2009 03:28 PM
neighborm
11-26-2008 09:12 AM
JimMayor007
07-01-2007 03:04 AM
T_Wrecks
11-17-2006 07:15 PM
bfjohns
11-06-2006 09:22 PM
Quick Reply: broken ring
