Will the newer Mazda wheels fit my car?
Old 04-04-2007, 05:04 PM
LS7 Thunder's Avatar
Default Will the newer Mazda wheels fit my car?
Hi,
I have a 98 626 5-speed, still with the steel rims and snap-on covers. I wanted to "update" the looks a little bit, and wanted to find out if any of the newer late model Mazda sedan rims will work. Is there a way to find out the specs of my rims (it has a 5-lug pattern), but I'm not sure on the offset.
Thanks,
Old 04-04-2007, 05:53 PM
sstlaure's Avatar
Default RE: Will the newer Mazda wheels fit my car?
You could measure your rims. Most likely it's a 6.5" wide wheel, but I'm not positive. You need a 5 lug 114.3mm bolt spacing (measure the distance between (2) lugs not right next to each other for bolt spacing)
Using a tape measure or ruler,
1) Measure the overall width of the rim from outer edge to outer edge - call this measurement "A"
2) Measure from mounting surface of the rim to the inner edge of rim - call this measurement "B"
B - (A/2) = offset
Old 04-04-2007, 07:25 PM
Thanks SS!
73Chalngr
02-10-2014 04:12 AM
UseYourNoggin
09-10-2013 06:27 PM
eliasg
04-28-2010 01:25 PM
shoreline
11-23-2009 10:38 PM
JDM86
10-17-2006 05:10 PM
Quick Reply: Will the newer Mazda wheels fit my car?
