1989 929--trans starting in 2nd or 3rd gear
Old 08-18-2007, 06:03 AM
madhatter's Avatar
Default 1989 929--trans starting in 2nd or 3rd gear
I have an 89 929 that wants to start out in 2nd or 3rd gear from a stoplight instead of 1st. If I shift down to 1 or 2at a light, 1st works fine and shifts as it should to the next gear. The trans shifts fine in D once it reaches 3rd gear on the highway, it's just pulling away from lights that it does not work correctly. Is this a solonoid or something worse? Thanks in advance.
Dave
Old 08-27-2007, 11:57 AM
hixx's Avatar
Default RE: 1989 929--trans starting in 2nd or 3rd gear
I believe the 89 still had a mechanical governor on the output shaft. Removing the tailshaft housing will give you access to it.
ThoroughConcept
Street/Strip
05-03-2012 05:14 PM
greenmtgirl14
04-29-2011 02:29 AM
millenia95
04-20-2007 04:13 AM
xyster
10-12-2006 11:27 PM
the_gray_mazda6
11-24-2005 01:56 AM
Quick Reply: 1989 929--trans starting in 2nd or 3rd gear
