Mazda Radio code reset
  #261
Old 02-16-2016, 11:45 AM
victoriaench's Avatar
Question Radio Code for Mazda Premacy
Originally Posted by raul84
My radio is locked (blinking ERR). If you know how to fix it please help.
Here is picture of the radio:
http://codedradio.info/pics/MAZDA/cq-lm0920a.jpg
Have the same problem here.. have you already fixed it?
  #262
Old 02-29-2016, 01:20 PM
Mazzy3's Avatar
Hi, it's been a while since I had this "ERR" problem with my Mazda 3 which came about after taking the battery off to charge it. I've just had to replace the original battery after 11 years! can you believe it! This time I put on a old back up battery while I went for the new one and then took it off again and fitted the new battery! Guess what? No error message at all! Nothing, just lost the preset stations that's all! I'm thinking that if you don't leave the battery disconnected for too long, and fit another straight away, you may not get this problem.
  #263
Old 03-15-2016, 07:20 AM
clparedes's Avatar
Default HELP: Mazda Tribute 2006 Radio Code
Step one:- press one at a time- preset 6, AM, Auto M, Seek ^ (up).
Step Two:-Input this number, 4989.
Step Three:- Press and hold Auto M and Preset 6 together.
Step Four:- The Word 'GOOD' will appear on the screen indicated that the radio will work.
Step Five:- Reprogram new Antitheft code into radio as per instruction manual.
Hi,
I have been searching within the forum for quite some time and would really need help in figuring out which buttons to press.
The post has the the buttons preset 6, AM, Auto M, Seek ^ (up) swhich are not present on our radio,
Attached is the picture of the schematics that we have.
Please advise on what are the counterparts of these buttons.
Thanks a lot!
  #264
Old 04-21-2016, 01:49 AM
gogomaria's Avatar
Default Mazda 2 Touring alloy '07
I registered to thank you.
3511 worked for me, I went through the whole thread.
Such a relief!!
Thank you again, I was about to replace the radio CD.
Greetings from Greece.
  #265
Old 07-07-2016, 10:09 AM
seshu81's Avatar
Default Mazda 3 sport 2004 model
I got error after trying 3 wrong codes. Now I am trying to enter your 4989 but unfortunately the combination 6, AM, Auto M, Seek^ Up is not showing me the ---- to enter the code 4989.
Even though I pressed the combinations it is flashing Err.
Can you please help me to enter the code 4989.
Originally Posted by Blue_SP20
Hi people,
Im going to hopefuly help alot of people out, but at the same time will upset Mazda dealers.
I have the code to unlock Mazda radios the have 'ERR' due to 3 wrong codes. Do not listen to mazda book that states 3 wrong codes make CD playing Inop req replacement...
121 Metro DW10*2 > 203028, MX5 NB30P2, Milennia,323 BJ10*2, 626 GF10S2, Tribute.Step one:- press one at a time- preset 6, AM, Auto M, Seek ^ (up).Step Two:-Input this number, 4989.Step Three:- Press and hold Auto M and Preset 6 together.Step Four:- The Word 'GOOD' will appear on the screen indicated that the radio will work.Step Five:- Reprogram new Antitheft code into radio as per instrution manual.
Hope this helps some people out, save you some money as so.
  #266
Old 08-03-2016, 06:09 PM
SpirosLavranos's Avatar
Default Mazda 2 eu model working working wornkig
Originally Posted by Master P
The code for mazda 3 radio units is 3511 then press 6 and auto m and you should see the message 'good' appear in the l.c.d display.
I have Mazda 2 2009' model and I followed your instructions and the code 3511 I finally my radio is working!!!
For Mazda 2 eu models just follow the upper instructions and put 3511.
THANK YOU so much!!!
You save me!!!
  #267
Old 08-17-2016, 07:15 AM
kyliedyer69@gmail.com's Avatar
Hi, I have a Mazda 3 and have tried both 4989 & 1414 but neither work 😞are there any other codes I could try please
  #268
Old 08-17-2016, 07:32 AM
Amazing thank you 5311 worked a treat
  #269
Old 08-22-2016, 05:06 PM
Skuttyford's Avatar
Default Nothing works
I have the same problem. I've tried the 6, AM, Auto M, Seek Up combination and the hold power button and AM for ten seconds suggestion but nothing happens. Err just keeps flashing. Any other options?
  #270
Old 12-05-2016, 11:41 AM
sjestew's Avatar
my thanks to blue and the forum for this old thread followed the procedure on my 2002 323f and with the addition of 1414 instead of 4989 it works brill the book says it needs a new radio what a con!
Quick Reply: Mazda Radio code reset
