Mazda 6s - P0300
Old 01-17-2015, 08:01 PM
Benjatank Smith's Avatar
Default Mazda 6s - P0300
My fiancé drives a 2005 Mazda 6s 3.0L and its throwing a CEL code of:
P0300 Random/Multiple Cylinder Misfire Detected
Am I correct in assuming the heli-coils and sparks are in need of replacement?
We already had one of the coils replaced that died on us during a road trip, I know it's bad to replace just one but it ended up being a used coil and the mech told us it was bound to fail again in the future.
Thanks in advance for your guys insight!
Old 01-17-2015, 09:34 PM
hixx's Avatar
You can buy a set of 6 on Ebay for $50.00. That's the best way to go. Replace all of them at once.
Old 01-18-2015, 04:03 AM
Possible Cause/Causes, as per workshop manual.
• CKP sensor malfunction
• CMP sensor malfunction
• Ignition coil malfunction
• Ignition system malfunction
• MAF sensor contamination
• Excess air suction in intake air system (between MAF sensor and intake manifold)
• Fuel pump malfunction
• Fuel pressure regulator (built-in fuel pump unit) malfunction
• Fuel line clogged
• Fuel filter clogged
• Fuel leakage in fuel line
• Fuel runout
• Poor quality fuel
• Purge control solenoid valve malfunction
• PCV valve malfunction
• EGR valve malfunction
• Vacuum hoses damages or improper connection
• Related connector and terminal malfunction
• Related wiring harness malfunction
• Insufficient compression
• Variable valve timing control system improper (LF, L3)
Old 02-12-2015, 01:26 AM
Gord'.'s Avatar
I thought a heli-coil was a thread repair kit
modpup
11-28-2017 08:43 PM
rkissock
10-29-2007 11:08 AM
BMilly
10-13-2007 09:48 PM
vikas21
08-07-2007 11:12 AM
buldozr
01-18-2007 11:21 PM
Quick Reply: Mazda 6s - P0300
