How to replace belt for alternator 94 MX-3
Ok I have a 94 MX-3 4 banger and my alternator belt broke. I have looked everywhere for what bolts need loosened to release tension on that belt and the other belt that is in front of it. I can't seem to find a diagram anywhere. Any info you may have would be appreciated because I am lost.
RE: How to replace belt for alternator 94 MX-3
It's tight but the bolts your looking for are on the PS pump. First loosen the lower PS pump adjuster lock bolt ( 14mm as i recall) then with a ratchet/extension and wobble socket you can access the adjuster bolt going through the radiator support beside the headlight. Should be a hole big enough to get to it. Like i said it is tight and not well designed imo but with a few bandaids you can do it.
