Injector Problem - I think
Old 02-26-2005, 06:01 PM
DLMiner's Avatar
Default Injector Problem - I think
Ok, I replaced the engine in my car as we discovered there was no saving the other one, sort of a lost cause when the rod is sticking out the side of the block.
Anyways, I bought a new engine and installed it, however the injectors won't open. If you squirt fuel into the intake where the throttle positioner is, it will run until the fuel is exhausted. We've got plenty of fuel pressure from the fuel pump about 70-75psi, and the sensors are all good.
I am at a loss here as to what the problem is. Chiltons is no help at this point because there is no explaination in the book as to what to do when you are pulling your hair out.
De
Old 02-26-2005, 10:05 PM
Default RE: Injector Problem - I think
First I would check Power at your injectors...if that isnt the problem Then i would have to say the PCM requires a "reflash" or replacement. Hope this helps.
luce az
04-10-2010 09:10 PM
chriscisme
05-29-2007 09:11 PM
john2568
02-21-2007 06:17 PM
bigzoom
05-22-2006 01:18 PM
jeff1202
06-27-2005 08:01 AM
Quick Reply: Injector Problem - I think
