Go Back   Mazda Forum - Mazda Enthusiast Forums > General Mazda Forums > General Tech
Sign in using an external account
Register Forgot Password?
Search
LinkBack Thread Tools Search this Thread
Old 03-26-2005, 12:35 AM
Default '94 626 idle problem
My '94 626 has an idling problem. With the clutch in the engine revs between 800-2000 rpm. The engine changes idle speed a few times a minute. I had a mechanic look at the engine and he sprayed something near the back passenger side of the engine and it made the idle rev up. He said that it was probably a head gasket leak. Anyone have any input on what this problem is and/or how to fix it? The engine has 192,000 miles. I was thinking about using some RTV silicone to try to plug up any leaks there might be in the head gasket. Any help would be much appreciated. Thanks.
Register today for free or log-in if already registered to remove this ad!
Old 04-11-2005, 10:41 PM
Default RE: '94 626 idle problem
sounds more like a intake gasket leak. headgaskets leak oil & coolant not vacuum which is causing your idle to change when he
sprays it, must be a 4 cy 2.0l, seen alot of intake gaskets go out on them at higher milage.
__________________
zoom-zoom
Old 01-22-2007, 06:55 PM
Hi,
Any idea what an intake gasket should cost ?
My Son's car just went in for one........
Thanks,
Mark
Tags
20, 2000rpm, 626, adjustment, gasket, idle, idles, intake, liter, low, mazda, speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Med Center Mazda
Pelham, AL 35235
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
