93 Mazda MX-6 V6 Won't Start - Mazda Forum - Mazda Enthusiast Forums
Thread Tools Search this Thread
Old 02-01-2007, 07:14 PM
Default 93 Mazda MX-6 V6 Won't Start
I have a 1993 Mazda MX-6 with a V6 motor. I was driving it home and it shut off, unable to restart it. It will start every once in awhile and run for a minute and shut back off again. I had the distributor replaced 2 years ago. Can Anyone help me?
Old 03-26-2007, 12:51 PM
Default RE: 93 Mazda MX-6 V6 Won't Start
Sounds like the distributor. I have the same car. It did the same thing at about 50K miles. This is a known issue with that year MX-6. On some, once it cools off it will restart and run for a little while. Did you replace with a used distributor last time? You may have got one with the same issue. I have heard you can repair just the part of the distributor that is bad instead of buying a new one which is very expensive. MX-6.com may have some more info on this - worth a try. Good luck.
Old 04-25-2007, 06:39 AM
there are lots of things to look at when car won't start. here are some of the possible causes: No fuel pressure. it might be bad fuel pump relay. Can you hear the pump running? or no ignition spark, - it could be a bad coil. DME problem or bad mercedes rotor arm. try also looking at dirty connections, clean everything. try to check all your mazda truck parts, then update us regarding this matter.
Thread Thread Starter Forum Replies Last Post
Brake problems front. 1 won't retract, other won't move Richard Mazda Millenia 0 05-02-2008 11:49 AM
86 626 won't start with starter, but will push start greggstonecipher Mazda 323,Mazda 626 & Mazda 929 1 03-30-2007 11:17 AM
1999 Mazda B2500 won't start Hizzoner General Tech 2 01-21-2007 09:35 AM
mazda 626 won't start aceintx Mazda 323,Mazda 626 & Mazda 929 2 12-12-2006 02:13 PM
Mazda 626 95 Won't start Ryanezek36 Mazda 323,Mazda 626 & Mazda 929 1 04-14-2006 07:10 PM
Tags
1993, 93, distributor, dtart, enthusiasts, forum, fuel, mazda, mx, mx6, pump, relay, run, sounds, spark, start, v6, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
